It is currently Mon May 25, 2026 4:00 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Sat Oct 20, 2001 7:53 am
Which are the correct part numbers for the wheel bearings and the seals for '66 Dart with K/H 4-piston disk brakes? Not Mopar original part numbers, but something I can go with to the bearing shop. Like SKF, FAG brand and their number.
Original parts are no longer available here, and dealers catalog (still there, with separate pages after 35 yrs use) has only Mopar ID's, which I cannot translate. I want to see that new ones are available before I put the car on the trestle and to the pieces.
JKKo
jari@kuparikuviot.fi
PostPosted: Mon Oct 22, 2001 7:47 am
: Which are the correct part numbers for the
: wheel bearings and the seals for '66 Dart
: with K/H 4-piston disk brakes? Not Mopar
: original part numbers, but something I can
: go with to the bearing shop. Like SKF, FAG
: brand and their number.
: Original parts are no longer available here,
: and dealers catalog (still there, with
: separate pages after 35 yrs use) has only
: Mopar ID's, which I cannot translate. I want
: to see that new ones are available before I
: put the car on the trestle and to the
: pieces.
: JKKo
If the '66 KH brakes are the same as '71 KH 4-piston discs, which I think they are, then they are still available. I just bought a set about 2 months ago from my local parts store in Pasadena, CA (SKF, for about $10 each, and $10 for the seals). I got them at "The Source" at (626) 304-0090.
madsenl@caltech.edu
PostPosted: Mon Oct 22, 2001 9:15 am
: If the '66 KH brakes are the same as '71 KH
: 4-piston discs, which I think they are, then
: they are still available. I just bought a
: set about 2 months ago from my local parts
: store in Pasadena, CA (SKF, for about $10
: each, and $10 for the seals). I got them at
: "The Source" at (626) 304-0090.
: Lou
66 through 72, all A-Bodies and I think it even "cross ref." into. a few other applications.
Someone out there have a good bering book??
PostPosted: Sat Oct 27, 2001 11:33 pm
: 66 through 72, all A-Bodies and I think it even
: "cross ref." into. a few other
: applications.
: Someone out there have a good bering book??
: DD
I got them. Outer bearing Federal Mogul "A-2", inner "A-6" and the seal the same brand "6840S".
JKKo
