It is currently Tue May 19, 2026 10:17 am
PostPosted: Sat Oct 20, 2001 9:35 am
I adjusted/checked the valve settings on my 69 - 225 and they were off a little, according to what the "book" says to use.
The book says .012 intake and .024 exhaust.
That's what I tried to accomplish and I think I got them all close.
Is this correct? Or should I use a different setting for a motor with at least 196,000 miles on it?
I was thinking that if I got them too tight they might burn a few things or I would loose power?
Thanks for any info,
Talk at ya later,
Dan
gramma@dm-tech.net
PostPosted: Sun Oct 21, 2001 10:26 am
: I adjusted/checked the valve settings on my 69
: - 225 and they were off a little, according
: to what the "book" says to use.
: The book says .012 intake and .024 exhaust.
: That's what I tried to accomplish and I think I
: got them all close.
: Is this correct? Or should I use a different
: setting for a motor with at least 196,000
: miles on it?
: I was thinking that if I got them too tight
: they might burn a few things or I would
: loose power?
: Thanks for any info,
: Talk at ya later,
: Dan
.012 & .024 is a bit on the loose side, factory cams set at .010 & .020 but I tend to run the exhaust on the loose side (.021 - .022) to be safe.
If your .012 / .024 setting sounds OK (not any loud ticking sounds) then you may want to run it for a while, then recheck / re-set later. I do not think you would see any real performance difference between the two settings.
Search the messages for "key word" valve adjustment (all) and review these posts for more info.
