| Honing oil alternative? https://slantsix.org/forum/viewtopic.php?t=28118 |
| Author: | DART68 [ Sat Mar 29, 2008 8:45 pm ] |
| Post subject: | Honing oil alternative? |
Is transmission fliud a good alternative to honing oil? If so does it matter what grade? You know, atf, mercon, dextron, and type f. Besides tranny fluid, what else is acceptable? Thanks-Dart68 |
| Author: | tophat [ Sun Mar 30, 2008 4:56 am ] |
Do you mean for honing the engine cylinders? If so, then yes I have used it for years. I use whatever grade I have around or is cheapest at the parts store. For brake cylinders I only use brake fluid. TopHat |
| Author: | LUCKY13 [ Sun Mar 30, 2008 5:04 pm ] |
3 in1 oil works pretty good, And I have even used Kerosene. You really dont want something that is to slippery, you want it to cut, but clean out the stone as its cutting, but without gaulding. Jess |
