It is currently Thu Nov 26, 2026 6:57 am
 Post subject: Honing oil alternative?
PostPosted: Sat Mar 29, 2008 8:45 pm
Is transmission fliud a good alternative to honing oil? If so does it matter what grade? You know, atf, mercon, dextron, and type f. Besides tranny fluid, what else is acceptable?
Thanks-Dart68
PostPosted: Sun Mar 30, 2008 4:56 am
Car Model: 63 Dart 81 D150
Do you mean for honing the engine cylinders? If so, then yes I have used it for years. I use whatever grade I have around or is cheapest at the parts store. For brake cylinders I only use brake fluid.
TopHat
PostPosted: Sun Mar 30, 2008 5:04 pm
3 in1 oil works pretty good, And I have even used Kerosene. You really dont want something that is to slippery, you want it to cut, but clean out the stone as its cutting, but without gaulding.
Jess
