It is currently Sat May 23, 2026 12:48 am
PostPosted: Tue Oct 30, 2001 11:06 am
In swapping around transmissions (trying to keep my beloved pushbuttons), I've lost part of the kickdown assembly for my '64 Valiant 904. It's the slotted part that goes between the kickdown rod and the lever on the transmission. As I recall, it is about 5" long, with about a 1/4" slot over most of the length, and a short 1/4" UNF or so stud on one end.
1. Does anyone have one to sell, or can someone give me a sketch with dimensions so I can fabricate one?
2. Will the cable kickdown / pedal / throttle cable from a Super Six work with my one barrel as in interim measure? (I'm planning to go Super soon)
Thanks for any assistance. Oh, and thanks for all the tips, info, and the articles on this forum! I know it's work, but I for one really appreciate it.
dobie79423@yahoo.com
PostPosted: Tue Oct 30, 2001 9:06 pm
: In swapping around transmissions (trying to
: keep my beloved pushbuttons), I've lost part
: of the kickdown assembly for my '64 Valiant
: 904. It's the slotted part that goes between
: the kickdown rod and the lever on the
: transmission. As I recall, it is about
: 5" long, with about a 1/4" slot
: over most of the length, and a short
: 1/4" UNF or so stud on one end.
: 1. Does anyone have one to sell, or can someone
: give me a sketch with dimensions so I can
: fabricate one?
: 2. Will the cable kickdown / pedal / throttle
: cable from a Super Six work with my one
: barrel as in interim measure? (I'm planning
: to go Super soon)
: Thanks for any assistance. Oh, and thanks for
: all the tips, info, and the articles on this
: forum! I know it's work, but I for one
: really appreciate it.
Did you already see this diagram in the Hyper-Pak linkage article?
PostPosted: Wed Oct 31, 2001 6:21 am
: Did you already see this diagram in the
: Hyper-Pak linkage article?
: DD
I missed that drawing. Thanks! The part I'm looking for is the lower half of "ROD 14-11-9"
