It is currently Thu Oct 15, 2026 11:14 pm
 Post subject: lowering a sixty seneca
PostPosted: Mon Apr 14, 2008 12:39 am
does anyone have suggestions on equipment required/necessary to lower a 1960 dodge seneca four door. please email me at ichon@comcast.net thanks, chas
CAK
PostPosted: Mon Apr 14, 2008 9:51 am
There will be others chiming in on this, but. The quick dirty way is to crank down the torsion bars for the front end, and install some spacer blocks between the rear springs and the read end.
As you probably know you will need to have the front end realigned and you are giving up some wheel travel.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Mon Apr 14, 2008 8:07 pm
How low do you want to go? The torsion bar/spacer block trick I think is only good for an inch, 2 max, before the suspension just isn't...suspensiony anymore.
