It is currently Sun Nov 15, 2026 12:37 pm
 Post subject: sort of a dumb question
PostPosted: Thu Apr 03, 2008 1:18 pm
When the car is in gear, clutch pedal not pushed in, is the throwout bearing still turning (in contact with clutch cover) or is it not in contact with clutch cover, if correctly adjusted?
PostPosted: Thu Apr 03, 2008 1:28 pm
If properly adjusted, the TO bearing should not be in contact with the clutch fingers, when not pressing on the pedal.
PostPosted: Thu Apr 03, 2008 1:45 pm
This relates to the "1 inch of free play" adjustment at the top of the clutch pedal travel.
If you have some free play, that usually pulls the TO bearing back enough so it does not spin when the pedal is not being pressed.
You can test this by slightly depressing the pedal through the free-play, you should be able to hear/" feel" the TO bearing as it makes contact and start spinning.
PostPosted: Thu Apr 03, 2008 5:21 pm
Thanks, I'll try for one inch of free play. The new bearing is deeper than the old, cheap one.
