It is currently Mon Nov 09, 2026 8:39 am
PostPosted: Sat Apr 05, 2008 11:21 pm
I installed all aftermarket gauges in my 73 Swinger. In the dash panel, I used 0.312 diameter LED lights These in my dash panel for my turn signal indicators, brights indicator , and brake warning light. For each light, I used the sender wires from the round plug behind the panel and a ground. They all work except for the brake warning light.
I thought maybe it needed power to it in addition to the sender wire, but when I tried that it just blew the fuse. Anybody have any ideas?
PostPosted: Sun Apr 06, 2008 4:41 am
Remember that LEDs work in one direction only, because the "D" stands for diode. Try swapping the wires and see if it works then.
(It's also possible you got a defective LED...)
Users browsing this forum: Ahrefs [Bot] and 3 guests
