It is currently Sun Nov 15, 2026 9:38 pm
 Post subject: 7 1/4 axel questions
PostPosted: Tue Apr 15, 2008 11:24 am
Are 1967 and 1963 A body 7 1/4 axels the same length? I was wanting to swap right side axels so Jessicas car will have all right hand threads.
Andrew
Wife's: 64 Valiant
PostPosted: Tue Apr 15, 2008 11:43 am
Yes, the axles are the same length. I would rather buy new studs or knock the studs out of the other axle and put them in the car than remove the existing axle shaft and replace the seal. Just personal preference, but if you don't have an impact wrench and spare lug nuts to pull the studs into the axle replacing the shaft is probably easier.
PostPosted: Tue Apr 15, 2008 2:03 pm
I am rebuilding the thing......installing a SG, and all new bearings and seals.Thanks for the info Josh!!
Wife's: 64 Valiant
