It is currently Sat Nov 21, 2026 8:34 pm
 Post subject: Cam quest
PostPosted: Sat Apr 19, 2008 11:43 am
Hi All - long time no smell
Since the erson supplier over here in South Africa does not supply erson anymore, and every one says the 264 comp is not worth it
I have discovered a cam grinder who can grind cams according to supplied specs - computer controled
SO
have a 68 fb cuda, 2 X 36 DCD7 Webers on a long ram manifold, 2.92 rear end, 904 TF, msd 6a recurved dizzy
that will have
Long tube headers, long collectors, x-pipe, dual 2 1/4 still considering witch silencers to use
Head and cam goes together IE cr and cam goes hand in hand so headwork will be done with cam
Car must be a power cruiser racing now and again
Specs please advice etc
BTW webers are nice but HORRIBLY expensive in us terms ~ $1100 for the two
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
