It is currently Mon Nov 30, 2026 12:58 pm
 Post subject: VALVE LASH SETTINGS
PostPosted: Fri Nov 09, 2001 10:09 am
Building up a 225 using a Hughes solid lifter cam (107 Centerline, 441 Lift, and 224 Duration @.050 tappet Lift). Hughes says to set the Intake Cold Lash at .015 & Exhaust Cold at .018. Intake hot lash at .018 and Exhaust hot lash at .020. Sounds a little loose to me. Any comments on these settings appreciated.
usclstaffingnet@sprintmail.com
 Post subject: Re: VALVE LASH SETTINGS
PostPosted: Sat Nov 10, 2001 10:48 am
: Building up a 225 using a Hughes solid lifter
: cam (107 Centerline, 441 Lift, and 224
: Duration @.050 tappet Lift). Hughes says to
: set the Intake Cold Lash at .015 &
: Exhaust Cold at .018. Intake hot lash at
: .018 and Exhaust hot lash at .020. Sounds a
: little loose to me. Any comments on these
: settings appreciated.
.020 is about right, that is where all the stock cams "lash" at. You have to start somewhere and the cam maker's recommended setting is a good place to start. Get it running and "tweek it" from there.
