It is currently Fri Nov 20, 2026 3:17 pm
 Post subject: 225 cam
PostPosted: Tue Apr 22, 2008 3:52 pm
i am building a 225 for street driving and am wondering what type of cam and what cam centerline to use. this is my first /6 and i have only built a few motors. looking at the comp 264s
220dur. @.50 int+exh
.44 lift int+exh
106 int. centerline
at sometime in the future i might put a blower on it.
PostPosted: Tue Apr 22, 2008 4:17 pm
Welcome! The search tool in the upper right hand corner will be your friend for this forum. Lot's of people have come through and asked the same questions you will ask, which is fine, but kinda wastes our time for the general questions we already answered. That being said this is a great group of people who help through thick and thin. If you serious about the blower you'll want to look at the first link. Lot's of people have said their going to add blank and do 900hp. Start easy this isn't a widely known performance engine with a lot of parts availble. Clifford will have some stuff but don't suggest going through them. The cam I would run is the second link listed. It's a nice middle ground that will let your run 15's NA or even run 6lbs through the chambers.
http://www.slantsix.org/forum/viewtopic.php?t=4472
http://store.summitracing.com/partdetai ... toview=sku
PostPosted: Tue Apr 22, 2008 4:20 pm
i have the clifford four barrel intake and headers. i also had the head seated with 1.70 int. and 1.44 exh. installed.
PostPosted: Tue Apr 22, 2008 7:52 pm
I am doing the same type of engine on a budget. After looking at the cams avalible the price tags for each, I had a local cam grinder increase the valve lift of a stock cam to around 0.44 and kept the duration and overlap the same ($50). I installed it 3 degrees retarded in hope of increasing the upper end preformance a little. The stock cams advertize a lift of over .40 but the ones I found were in the 3.6 range. Also the rocker arm ratio was about 1.41 not the 1.5 advertized. I am planning in the far future to try to turbo charge this engine and did not want the larger overlap which I have read can cause trouble with turbos and blowers. So with the bumped up lift the stock cam should work well. I also read an artical that stated that lifting the valve more than 1/4th the diameter of the valve gives only marginal return and can lead to early lobe wear. At that lift the air is more greatly hindered by the seat diameter then by the clearence between the seat and the valve. I can not tell you if it works yet or not because it just got assembled tonight and won't see the engine bay for about another six months.
just what i'm doing, ain't say'en it right
1964 barracuda 198 slant
PostPosted: Wed Apr 23, 2008 7:47 am
Go to the parts for sale section and look at the" Erson group cam buy" stickie at the top. I would go with a 270 Erson or a new split profile 270/280.
My 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Amazon [Bot], Google [Bot] and 10 guests
