It is currently Mon Nov 30, 2026 10:06 am
PostPosted: Sun Nov 11, 2001 8:19 pm
What donor cars have 8.25 inch rear ends that will be a direct swap? I'm guessing Diplomats, New Yorker's etc. Any others?
My car is an '80 Volare 4 door with a 7.25 in rear.
mopar@canoemail.com
PostPosted: Mon Nov 12, 2001 2:20 am
: What donor cars have 8.25 inch rear ends that
: will be a direct swap? I'm guessing
: Diplomats, New Yorker's etc. Any others?
: My car is an '80 Volare 4 door with a 7.25 in
: rear.
You can try these:(make sure the axle is correct, they changed the length somewhere in 79-80)
76-80 Aspen/Volare
77-81 Diplomat
77-81 LeBaron
You may need to upgrade your brakes, and you will need the driveshaft from the donor car. (assuming donor car has the same tranny your car has...)
good hunting, should be an easy find, still a lot of Dippy cop cars in the yards with 3.21 sure-grips to be had...
res0aus2@verizon.net
