| Do tie rod ends and sleeves interchange thru 72-73 A-bodies? https://slantsix.org/forum/viewtopic.php?t=28577 |
| Author: | radarsonwheels [ Fri Apr 25, 2008 12:57 am ] |
| Post subject: | Do tie rod ends and sleeves interchange thru 72-73 A-bodies? |
I have '72 parts can I replace one end on my '73, or do I have to do both and a sleeve? Or maybe the taper fit on the knuckles and or drag link holes is different too? I let some kid at iffylube rupture a boot on one of four new ends, and I am getting around to replacing it. Thanks radar in philly |
| Author: | Dart270 [ Fri Apr 25, 2008 6:01 am ] |
I believe all A body tie rods and ends are the same (9/16" diam). A good way to check this is go to rockauto.com and look up different part numbers for different years. Lou |
| Author: | Joshie225 [ Fri Apr 25, 2008 7:39 am ] |
There are different tie-rod ends listed for different years, but all A-body tie-rods interchange. Late A-body tie rod ends ('73-'76) were cheaper than what was listed for my '66 Dart years ago so I used the later ones. Unless you had them side by side you'd never see the minute differences. |
| Author: | radarsonwheels [ Fri Apr 25, 2008 8:37 pm ] |
| Post subject: | Thanks |
I meant to go hook it up tonight, but it looked like rain. There's always tomorrow. kevin |
| Author: | slantfin [ Sun May 04, 2008 7:23 pm ] |
You can also fit in some beefier tie rods from a B-body? I can't find my crib sheet with the model and years to ask for. |
| Author: | slantvaliant [ Sun May 04, 2008 8:59 pm ] |
Quote: You can also fit in some beefier tie rods from a B-body? I can't find my crib sheet with the model and years to ask for.
C-body (11/16") tie rods also work.HERE is some information. |
| Author: | slantfin [ Mon May 05, 2008 7:28 pm ] |
That's right, the C body ones are the upgrade that fits the A body. |
