It is currently Thu Nov 26, 2026 5:31 am
PostPosted: Fri Apr 25, 2008 12:57 am
I have '72 parts can I replace one end on my '73, or do I have to do both and a sleeve? Or maybe the taper fit on the knuckles and or drag link holes is different too? I let some kid at iffylube rupture a boot on one of four new ends, and I am getting around to replacing it.
radar in philly
madam im adam
PostPosted: Fri Apr 25, 2008 6:01 am
I believe all A body tie rods and ends are the same (9/16" diam). A good way to check this is go to rockauto.com and look up different part numbers for different years.
PostPosted: Fri Apr 25, 2008 7:39 am
There are different tie-rod ends listed for different years, but all A-body tie-rods interchange. Late A-body tie rod ends ('73-'76) were cheaper than what was listed for my '66 Dart years ago so I used the later ones. Unless you had them side by side you'd never see the minute differences.
 Post subject: Thanks
PostPosted: Fri Apr 25, 2008 8:37 pm
I meant to go hook it up tonight, but it looked like rain. There's always tomorrow.
kevin
madam im adam
PostPosted: Sun May 04, 2008 7:23 pm
You can also fit in some beefier tie rods from a B-body? I can't find my crib sheet with the model and years to ask for. :?
PostPosted: Sun May 04, 2008 8:59 pm
C-body (11/16") tie rods also work.
HERE is some information.
PostPosted: Mon May 05, 2008 7:28 pm
That's right, the C body ones are the upgrade that fits the A body.
