It is currently Mon Nov 30, 2026 3:13 am
 Post subject: Manifold milling?
PostPosted: Mon Nov 12, 2001 11:17 pm
I've got a 78 S6 set-up. I want to have them milled before I bolt them on. You know, to avoid any possible vacum or exaust leaks. Where is someplace near or in Los Angeles that is reliable and has reasonable prices?
drucker@sbcglobal.net
 Post subject: Re: Manifold milling?
PostPosted: Tue Nov 13, 2001 9:57 am
: I've got a 78 S6 set-up. I want to have them
: milled before I bolt them on. You know, to
: avoid any possible vacum or exaust leaks.
: Where is someplace near or in Los Angeles
: that is reliable and has reasonable prices?
Hollywood Machine Shop in Pasadena, on Walnut Ave, does good work.
PostPosted: Tue Nov 13, 2001 12:19 pm
Call around and ask if the shop(s)can resurface a manifold's mounting surface. (this is really a grinding operation so I would not call it "milling")
The shop I use in the Bay ares charges $18.00 to do a set.
