| Manifold milling? https://slantsix.org/forum/viewtopic.php?t=2864 |
| Author: | DART"68" [ Mon Nov 12, 2001 11:17 pm ] |
| Post subject: | Manifold milling? |
I've got a 78 S6 set-up. I want to have them milled before I bolt them on. You know, to avoid any possible vacum or exaust leaks. Where is someplace near or in Los Angeles that is reliable and has reasonable prices? drucker@sbcglobal.net |
| Author: | Dart270 [ Tue Nov 13, 2001 9:57 am ] |
| Post subject: | Re: Manifold milling? |
: I've got a 78 S6 set-up. I want to have them : milled before I bolt them on. You know, to : avoid any possible vacum or exaust leaks. : Where is someplace near or in Los Angeles : that is reliable and has reasonable prices? Hollywood Machine Shop in Pasadena, on Walnut Ave, does good work. Lou |
| Author: | Doc [ Tue Nov 13, 2001 12:19 pm ] |
| Post subject: | Re: Manifold "Resurfacing" |
: I've got a 78 S6 set-up. I want to have them : milled before I bolt them on. You know, to : avoid any possible vacum or exaust leaks. : Where is someplace near or in Los Angeles : that is reliable and has reasonable prices? Call around and ask if the shop(s)can resurface a manifold's mounting surface. (this is really a grinding operation so I would not call it "milling") The shop I use in the Bay ares charges $18.00 to do a set. DD |
