It is currently Wed May 13, 2026 7:52 am
 Post subject: boost and compression
PostPosted: Mon Apr 28, 2008 10:40 pm
just seein wut you turbo guys are runnin as far as compression.
my buddy like 240 nissans(booo) and wont shut up about turbo bla bla so it got me thinkin
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Mon Apr 28, 2008 11:38 pm
CR will be determined by cam, combustion chamber design/piston design, what kind of fuel and how much boost. There is a huge difference in modern engine designs and these old engines. We run 10.5:1 CR in our race honda with 2.5kg boostpressure, it put out 512rwhp with 2L (stock) bottom end.
My slant will run at ~8:1 cr, but I'm sure the gurus at this great forum has more experience boosting a slant.
Note that with a high duratiing cam with big overlap your actual CR will be lower than the static.
Good luck,
Rob,
Dart -74 4dht.
