It is currently Mon Nov 30, 2026 1:01 am
PostPosted: Thu Nov 15, 2001 8:04 am
I just rebuilt my 223, and its pushing 300 h.p. I noticed one day, (about 2000 mi on motor) I had no oil pressure. Upon removal of the oil pump, I discovered the gear completely stripped on one side. So I changed oil and filter about twice to get the shavings out and it runs fine with a new oil pump. I need to know what I should do to prevent this in the future, or if it was one time bad luck. The cam is a brand new .460 lift from mopar, and the oil pump was also new hi volume. Any help would be greatly appreciated.
Jason T
TX
jasovanni@hotmail.com
PostPosted: Thu Nov 15, 2001 1:28 pm
: I just rebuilt my 225, its pushing 300 h.p.
: I noticed one day, (about 2000 mi on motor)
: I had no oil pressure. Upon removal of the
: oil pump, I discovered the gear completely
: stripped on one side. So I changed oil and
: filter about twice to get the shavings out
: and it runs fine with a new oil pump. I need
: to know what I should do to prevent this in
: the future, or if it was one time bad luck.
: The cam is a brand new .460 lift from mopar,
: and the oil pump was also new hi volume. Any
: help would be greatly appreciated.
This is a problem with the SL6, the SSRN technical department is working in earnest on this issue. Please help by down-loading and completing the Oil Pump Failure Survay linked below and mail it in as noted. It would be extreamly helpful if you can send-in your failed oil pump gear.
As for some possible fixes:
*Keep oil pressure reasonable. (50-60 psi max)
*Open-up / deburr all oil passageways. (helps reduce "work" & load on the gears)
*Check the cam to oil pump gear mesh. (use lapping or gear impression compound)
*Run a "Cam Button" to prevent the cam from "walking" forward.
*be sure oil pressure "bleed-off" holes are drilled in the cam & cam timing chain gear.
Help us help all SL6 owners / racers, complete a survay if you have ever had this failure.
Oil Pump Gear Failure Report
