| Id this tranny for me,please https://slantsix.org/forum/viewtopic.php?t=28750 |
| Author: | mopar_nocar [ Sun May 04, 2008 2:09 pm ] |
| Post subject: | Id this tranny for me,please |
anyone recognize which tranny this is? ![]() 3 more pics here: http://sanantonio.craigslist.org/pts/651188448.html sb |
| Author: | icaneat50eggs [ Sun May 04, 2008 2:57 pm ] |
I believe thats the a 833 od |
| Author: | mopar_nocar [ Sun May 04, 2008 3:20 pm ] |
Went to look at the tranny. Neither of my DS yokes fit the splines, it had a 10 spline input shaft and a date code stamped on it: 5/21/86. It had NP stamped all over it as well. I am curious as to what it came out of and how much trouble would it be to put into an A body. Any ideas? edit: The bearing retainer was 5.125" and I beleive this to be the 833 from a chevy truck/van. Will it bolt to a slant 6 bellhousing directly? thanks, sb |
| Author: | mopar_nocar [ Sun May 04, 2008 3:57 pm ] |
Were the input and output shafts all that GM changed? sb |
| Author: | Joshie225 [ Sun May 04, 2008 5:02 pm ] |
Wow, that thing is short! How long is it from the bellhousing face to the end of the tailshaft? I would imagine you could use this behind a slant with a chevy clutch disc, custom pilot bushing, longer driveshaft and custom speedometer cable. |
| Author: | mopar_nocar [ Sun May 04, 2008 5:26 pm ] |
That is one measurement I wish I had taken. From researching, it apparently is the same mounting to the BH as the Dodge trucks of the era. The guy who owns it said it was in a 64 impala when he bought it. I wonder if this swap would be worth the effort? sb |
| Author: | Joshie225 [ Sun May 04, 2008 6:15 pm ] |
I would look for a real Chrysler application A833OD. It will likely cost less to install and will certainly require less time to install and make work. |
