It is currently Mon Nov 16, 2026 9:25 pm
PostPosted: Sun May 04, 2008 2:09 pm
Car Model: 1974 W100; 72 Dart
anyone recognize which tranny this is?
3 more pics here:
http://sanantonio.craigslist.org/pts/651188448.html
sb
PostPosted: Sun May 04, 2008 2:57 pm
I believe thats the a 833 od
PostPosted: Sun May 04, 2008 3:20 pm
Went to look at the tranny. Neither of my DS yokes fit the splines, it had a 10 spline input shaft and a date code stamped on it: 5/21/86.:shock:
It had NP stamped all over it as well. I am curious as to what it came out of and how much trouble would it be to put into an A body. Any ideas?
edit:
The bearing retainer was 5.125" and I beleive this to be the 833 from a chevy truck/van. Will it bolt to a slant 6 bellhousing directly?
thanks,
sb
PostPosted: Sun May 04, 2008 3:57 pm
Were the input and output shafts all that GM changed?
sb
PostPosted: Sun May 04, 2008 5:02 pm
Wow, that thing is short! How long is it from the bellhousing face to the end of the tailshaft? I would imagine you could use this behind a slant with a chevy clutch disc, custom pilot bushing, longer driveshaft and custom speedometer cable.
PostPosted: Sun May 04, 2008 5:26 pm
That is one measurement I wish I had taken. From researching, it apparently is the same mounting to the BH as the Dodge trucks of the era. The guy who owns it said it was in a 64 impala when he bought it. I wonder if this swap would be worth the effort?
sb
PostPosted: Sun May 04, 2008 6:15 pm
I would look for a real Chrysler application A833OD. It will likely cost less to install and will certainly require less time to install and make work.
Users browsing this forum: Amazon [Bot] and 1 guest
