| Power Steering Pump - Whines! https://slantsix.org/forum/viewtopic.php?t=28762 |
| Author: | bwhitejr [ Mon May 05, 2008 3:59 am ] |
| Post subject: | Power Steering Pump - Whines! |
My power steering pump whines all the time. It still works, though. Can I buy parts to rebuild it at the auto parts store? Is it better to get a rebuilt one? Cost? Never had a power steering car before. bwhitejr |
| Author: | JackLe945 [ Mon May 05, 2008 9:35 am ] |
I'm not 100% sure on this but I think it is better to buy a new pump. |
| Author: | SlantSixDan [ Mon May 05, 2008 10:39 am ] |
See this thread and try the air bleed procedure described therein. Also check the condition of your fluid. If it's dark, gritty, burnt-smelling or otherwise "off", you're probably in the market for a new pump. It's going to be hard to find anything but a "reman" of questionable quality; about all you can do is steer(!) clear of known-lousy brands like Cardone. |
| Author: | KBB_of_TMC [ Fri May 09, 2008 10:22 am ] |
My '71 Saginaw pump suddenly developed a big leak at the front main seal; my local parts had a rebuilt kit for <$20. The rebuild was straight forward; easier than a carb rebuild. A couple of points 1a) the output hose/tube assembly was rusted solid and I had to get a not-quite-exact aftermarket replacement 1b) NAPA tried to palm off the wrong size (3/4") return hose on me when I specifically requested the right size (11/32"); eventually I got some 11/32" from a dealership 2) it takes a special puller to remove the pulley - I used an inexpensive one from Harbor Freight; I also have a KD Tools' one 3) There was a choice of 2 O-rings due to a production change - the details on which to use were on the backside of the instruction sheet in small print |
