It is currently Sun Nov 29, 2026 2:38 pm
 Post subject: Torque Straps?????
PostPosted: Mon Nov 19, 2001 5:31 pm
Anyone know who sells engine torque straps?
usclstaffingnet@sprintmail.com
PostPosted: Tue Nov 20, 2001 8:34 am
: Anyone know who sells engine torque straps?
Schumacher has one, see their website:
<A HREF="http://www.engine-swaps.com/">http://www.engine-swaps.com/</A>
The trick with doing a Torque Strap on a SL6 is to find a good place to mount it. Best location is up high and forward. One place I have used is the backside of one of the water pump mounting holes. (put a long bolt or stud through it)
Better yet, there is an undrilled / tapped boss up on the front of the head which makes a good location, it does need to be drilled and tapped.
I find that a good strap can be made from low cost Hardware store parts, get a piece of cable, some cable loops and ties, a "turn-buckel" and eye bolts will do the trick.
