| Torque Straps????? https://slantsix.org/forum/viewtopic.php?t=2885 |
| Author: | jamesM [ Mon Nov 19, 2001 5:31 pm ] |
| Post subject: | Torque Straps????? |
Anyone know who sells engine torque straps? usclstaffingnet@sprintmail.com |
| Author: | Doc [ Tue Nov 20, 2001 8:34 am ] |
| Post subject: | Re: Torque Strap from Schumacher |
: Anyone know who sells engine torque straps?
Schumacher has one, see their website: <A HREF="http://www.engine-swaps.com/">http://www.engine-swaps.com/</A> The trick with doing a Torque Strap on a SL6 is to find a good place to mount it. Best location is up high and forward. One place I have used is the backside of one of the water pump mounting holes. (put a long bolt or stud through it) Better yet, there is an undrilled / tapped boss up on the front of the head which makes a good location, it does need to be drilled and tapped. I find that a good strap can be made from low cost Hardware store parts, get a piece of cable, some cable loops and ties, a "turn-buckel" and eye bolts will do the trick. DD |
