It is currently Fri Jan 02, 2026 2:59 am
PostPosted: Mon May 12, 2008 9:41 am
What do I need to adjust my valves to with the Comp Cams 264S?
Last edited by 73dart_swinger on Mon May 12, 2008 4:12 pm, edited 1 time in total.
PostPosted: Mon May 12, 2008 9:54 am
6 Pack Dart
.010 Intake .012 Exhaust
PostPosted: Mon May 12, 2008 9:57 am
Car Model: 1974 W100; 72 Dart
Is it a stock adjustment? My erson is .022 on both.
sb
PostPosted: Mon May 12, 2008 9:59 am
If you want more bottom end torque and power, run a looser lash, .012 and .022.
It has allot steadier idle at higher intial advance settings. :D
PostPosted: Mon May 12, 2008 11:58 am
Comp Cams recommends .020/.022 with the 264S lobe and a 1.5 rocker.
Ground on a 110 LSA.
Recommended installed intake centerline is 106.
Slant Cecil
PostPosted: Mon May 12, 2008 12:14 pm
Recommended settings from the Comp Cam 264S 'Card' states .010 intake and .012 exhaust. That's what I'm set at and it runs great.
66Dart
PostPosted: Mon May 12, 2008 12:25 pm
IIRC, my card says .020/.022, I'll double check it this weekend.
Slant Cecil
 Post subject: Specs have changed...
PostPosted: Mon May 12, 2008 4:10 pm
Comp has changed some of the specs over the years, the old fatter lobes used the .020/.022 setting, my 252 card says .012/.012... my CCX cam says .012/.012 as well....
Now that most of their lobes are chebby lobes they are using a tighter 'spec' to keep the lifter on the ramp sadly enough....
