Comp 264 Valve Adjustment
https://slantsix.org/forum/viewtopic.php?t=28900
Author:  73dart_swinger [ Mon May 12, 2008 9:41 am ]
Post subject:  Comp 264 Valve Adjustment
What do I need to adjust my valves to with the Comp Cams 264S?
Author:  Fopar [ Mon May 12, 2008 9:54 am ]
.010 Intake .012 Exhaust
Author:  mopar_nocar [ Mon May 12, 2008 9:57 am ]
Is it a stock adjustment? My erson is .022 on both.
sb
Author:  Aggressive Ted [ Mon May 12, 2008 9:59 am ]
If you want more bottom end torque and power, run a looser lash, .012 and .022.
It has allot steadier idle at higher intial advance settings. :D
Author:  Slant Cecil [ Mon May 12, 2008 11:58 am ]
Comp Cams recommends .020/.022 with the 264S lobe and a 1.5 rocker.
Ground on a 110 LSA.
Recommended installed intake centerline is 106.
Author:  66Dart [ Mon May 12, 2008 12:14 pm ]
Recommended settings from the Comp Cam 264S 'Card' states .010 intake and .012 exhaust. That's what I'm set at and it runs great.
66Dart
Author:  Slant Cecil [ Mon May 12, 2008 12:25 pm ]
IIRC, my card says .020/.022, I'll double check it this weekend.
Author:  DusterIdiot [ Mon May 12, 2008 4:10 pm ]
Post subject:  Specs have changed...
Comp has changed some of the specs over the years, the old fatter lobes used the .020/.022 setting, my 252 card says .012/.012... my CCX cam says .012/.012 as well....
Now that most of their lobes are chebby lobes they are using a tighter 'spec' to keep the lifter on the ramp sadly enough....
