It is currently Sun Oct 11, 2026 1:30 pm
 Post subject: blower and bogging
PostPosted: Wed May 14, 2008 7:02 am
I finally got this car to this coast and I want to fix a few things. It runs fine, but off the line it bogs initially. If there is any gas, it pulls fine, but right off the line it stumbles badly. Any suggestions? It is only making about 5 or 6 pounds of boost.
Chris
1966 Dart GT supercharged slant 6
PostPosted: Wed May 14, 2008 4:00 pm
What carb are you using?
PostPosted: Thu May 15, 2008 4:52 am
Carter AFB 1721. Not really sure of the condition, but I may put a kit in it just for good measure.
PostPosted: Fri May 16, 2008 9:15 pm
I would try more initial advance and maybe bigger squirter's on accelerator pump. Does it surge at all when going down the road.
PostPosted: Sat May 17, 2008 4:03 pm
No noticeable surging. It gets up and goes once it is rolling.
Chris
PostPosted: Sun May 18, 2008 10:20 am
I suspect you have too little accelerator pump shot and may not be able to get enough accelerator pump delivery from your Carter carb. I'm thinking a Holley with a 50cc accelerator pump, blue cam and a fairly large nozzle. That would give a big initial pump shot and keep the engine from bogging off the line.
Users browsing this forum: Google [Bot] and 32 guests
