It is currently Fri May 22, 2026 3:41 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: Rear seal retainer
PostPosted: Sun Nov 25, 2001 10:04 am
Well, I'm actually putting my motor together. The head's done. The spinning parts are balanced and *almost* all of the parts are collected. I was looking thru the stuff and realized I don't have a rear seal retainer. How can this be! Well, I bought most of this at the last Spring Fling. Someone elses aborted project. I guess it didn't make it into the box. Anyway, finally, my question.
Are they all the same? Do any of you guys have one lying around so I don't have to go to Pick-a-part and rip a whole engine apart for one thing?
Mike
My Wacky Project
MAndreas@aol.com
 Post subject: Re: Rear seal retainer
PostPosted: Sun Nov 25, 2001 11:32 am
: Well, I'm actually putting my motor together.
: The head's done. The spinning parts are
: balanced and *almost* all of the parts are
: collected. I was looking thru the stuff and
: realized I don't have a rear seal retainer.
: How can this be! Well, I bought most of this
: at the last Spring Fling. Someone elses
: aborted project. I guess it didn't make it
: into the box. Anyway, finally, my question.
: Are they all the same? Do any of you guys have
: one lying around so I don't have to go to
: Pick-a-part and rip a whole engine apart for
: one thing?
: Mike
Well, I know that big blocks use the same type retainer, I don't know if the diminsions are the same though.
Eric W
My big B
ecwfury@webtv.net
PostPosted: Sun Nov 25, 2001 1:17 pm
: one thing?
: Mike
Mike, I have one laying on the workbench for a steel crank motor. (I think cast and steel are different?) E-mail me if ya want it. Dennis
slantzilla@excite.com
PostPosted: Mon Nov 26, 2001 9:42 am
: Well, I know that big blocks use the same type
: retainer, I don't know if the diminsions are
: the same though.
The seals are the same but the SL6 main seal retainer housing is a different shape so the BB unit will not work on a Slant.
One reason these retainers seem to "get lost" is that they are made of aluminum and if they get put into a "hot tank" for cleaning, they desolve, never to be seen again. Do you have the special bolts? (3/8 - 12 point head)
I have extras....when you get a replacement, be sure to "fit check" it to the empty block, just to be sure the seal aligns correctly. Mock everything up before the crank goes in.
 Post subject: Special Bolts?
PostPosted: Mon Nov 26, 2001 11:42 am
No I don't have the proper bolts. How can I get some?
Mike
MAndreas@aol.com
 Post subject: Re: Special Bolts?
PostPosted: Mon Nov 26, 2001 12:08 pm
: No I don't have the proper bolts. How can I get
: some?
: Mike
I think I have the ones that go with the retainer. If I do, I'll toss them in the box. Dennis
PostPosted: Wed Nov 28, 2001 7:58 am
: I think I have the ones that go with the
: retainer. If I do, I'll toss them in the
: box. Dennis
Hey Mike,
I think I have one in Pasadena. I'll be in back in town tomorrow and if Dennis hasn't already mailed you one, I can look for it if you like.
Still gotta give you a ride in the OD Dart too! NC has been real purty this last week.
Cheers,
PostPosted: Sat Dec 01, 2001 5:16 pm
: Hey Mike,
: I think I have one in Pasadena. I'll be in back
: in town tomorrow and if Dennis hasn't
: already mailed you one, I can look for it if
: you like.
: Still gotta give you a ride in the OD Dart too!
: NC has been real purty this last week.
: Cheers,
: Lou
i have several with bolts as well. i see no difference between the cast crank/steel crank reatainers, and have swapped them with no ill effects. i have also seen them with BOTH 3/8 6 point and 12 point bolts!.....chad
beardliz@msn.com
