It is currently Fri Jan 02, 2026 6:08 pm
 Post subject: ARP studs/bolts?
PostPosted: Thu May 22, 2008 8:27 pm
Do you guys reccomend using ARP main and rod cap bolts and head studs for the following build? :1964 225 block, 280 deg .465 lift cam, Clifford shorty headers, Offenhauser 4 bbl, Edelbrock 500, head ported, big valves, milled .100", block bored anywhere from .040-.080" over (not sure yet, block is at the shop). I won't be racing the motor, but I sure won't go too easy on it. Let me know what you guys think.
Stephan Nelle
PostPosted: Thu May 22, 2008 9:28 pm
I'd just do the rod bolts.
PostPosted: Sat May 24, 2008 11:45 am
Agreed. If you go with the main studs, you's have to get the block align-honed (not a bad idea anyway, though), and head studs make head removal/installation more challenging on a slant.
vm
PostPosted: Sat May 24, 2008 2:52 pm
+2.
I have a set of head studs in my turd and I'm not sure they really helped seal the head gasket anyway. :?
PostPosted: Sat May 24, 2008 10:45 pm
+2.
+3,
if I was to want a little more protection and was goign to try and turn higher RPM then the main studs would be what I added. It would need lign honed then, but that can only make it better if done right.
Jess
PostPosted: Sun May 25, 2008 7:41 pm
I did all 3, but recommend just the rod bolts for that one.
PostPosted: Wed May 28, 2008 11:10 am
I would say that the rod bolts are all that is "needed" as well. You really should have rods resized on any complete rebuild anyway, so why not put some good bolts in?
I like head studs for their bullet proof clamping of the head, but they are a real time consuming pain and can (will) make it impossible to get the head off with the engine in the car most of the time. Aside from that they are just about never needed on a street car.
One of the main things needed for a a good head gasket seal, or any seal for that matter, is flat, true and parallel surfaces. If they are right a good gasket and stock bolts will work fine on just about any engine. If they are not right, studs and even special gaskets might not fix it.
It also helps to chamfer all the holes slightly with a 45 degree counter sink.
You can probably have your block decked for less than head studs cost anyway.
PostPosted: Wed May 28, 2008 4:59 pm
So when degreeing the cam you are potentially not lining up the crank and cam timing marks? Is this done simply by offsetting the cam or crank sprocket one or two (or however many is required) from its regular location on the timing chain?
Stephan Nelle
PostPosted: Wed May 28, 2008 9:19 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Thats pretty expensive to have done right? I want this done to my drag engine...
PostPosted: Wed May 28, 2008 9:37 pm
I just read Crane Cams' article on degreeing cams. Pretty good and informative. Now I'm not so in the dark.
What's the best/easiest/most common way, if needed, to adjust the cam timing on the slant?
Stephan Nelle
PostPosted: Thu May 29, 2008 5:04 am
I find the easiest way is to drill the cam gear dowel hole, and use an offset bushing. I do this on all my engines, during assy, even if they degree in "right on". That makes it easier to change timing after the engine is in the car and running.
PostPosted: Thu May 29, 2008 11:09 am
A few hundred bucks, if I recall. Personally, I'll never build an engine without having it align-honed. It seems like a no-brainer to me. If you're going to build a short-block, do it right. Cut corners on the cylinder head if you have to — you can replace/modify it easier than pulling the whole engine. Just my $.02.
vm
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 19 guests
