It is currently Sat Nov 28, 2026 7:50 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: 198 vs 225
PostPosted: Wed Nov 28, 2001 2:31 pm
I would like to know is there a big difference in performance between these two motors with the same mods done to them. A friend has both and wants to build one to go in a 69 dart for some street-strip fun. thank you Chas..
cjc314@aol.com
 Post subject: Re: 198 vs 225
PostPosted: Wed Nov 28, 2001 4:38 pm
: I would like to know is there a big difference
: in performance between these two motors with
: the same mods done to them. A friend has
: both and wants to build one to go in a 69
: dart for some street-strip fun.
It is a matter of RPM vs torque... the 198 can be reved over 7000 rpm, 225 just won't do that.
The longer stroke 225 will produce more low RPM power so it is a matter of how you set-up the combo. If you are going to put in a wild cam, high stall converter & low rear end gear ratio, the smaller 198 can "spin out" about the same H.P.
If you can't support high RPM use, just pull the 7" con rods out of the 198 and build a "long rod" 225. Let's face it, at a .9 HP to cubic inch ratio, you are leaving about 24 horsepower behind with the 198 working at the same RPM as a 225.
PostPosted: Wed Nov 28, 2001 7:21 pm
: dart for some street-strip fun. thank you
: Chas..
Like the man sez: The only substitute for cubic inches is cubic money.
Charlie with the 170 slant
flturbo6@aol.com
 Post subject: Thank You *NM*
PostPosted: Fri Nov 30, 2001 9:20 am
cjc314@aol.com
