It is currently Fri May 22, 2026 1:59 pm
 Post subject: Thanks doctor dodge
PostPosted: Wed Nov 28, 2001 7:14 pm
That skip in my 75 dart is much better with the wire so I will take the instrument panel out and see if the problem is in the amp gauge. Could the ignition switch be shorting? Thanks again.
melam@nxs.net
 Post subject: Re: Thanks doctor dodge
PostPosted: Thu Nov 29, 2001 11:24 pm
: That skip in my 75 dart is much better with the
: wire so I will take the instrument panel out
: and see if the problem is in the amp gauge.
: Could the ignition switch be shorting?
: Thanks again.
Mike,
You should be able to reach the gauge terminals from the back without removing the cluster. I think they're 5/16"-wrench nuts. This is likely the problem - pretty common, especially if someone has monkeyed around under the dash.
Make sure to disconnect the battery first so you don't spot weld anything under the dash...
PostPosted: Fri Nov 30, 2001 9:59 am
: Thanks again. Thanks lou I will give it a try this weed end.
melam@nxs.net
