| Thanks doctor dodge https://slantsix.org/forum/viewtopic.php?t=2919 |
| Author: | mike elam [ Wed Nov 28, 2001 7:14 pm ] |
| Post subject: | Thanks doctor dodge |
That skip in my 75 dart is much better with the wire so I will take the instrument panel out and see if the problem is in the amp gauge. Could the ignition switch be shorting? Thanks again. melam@nxs.net |
| Author: | Dart270 [ Thu Nov 29, 2001 11:24 pm ] |
| Post subject: | Re: Thanks doctor dodge |
: That skip in my 75 dart is much better with the : wire so I will take the instrument panel out : and see if the problem is in the amp gauge. : Could the ignition switch be shorting? : Thanks again. Mike, You should be able to reach the gauge terminals from the back without removing the cluster. I think they're 5/16"-wrench nuts. This is likely the problem - pretty common, especially if someone has monkeyed around under the dash. Make sure to disconnect the battery first so you don't spot weld anything under the dash... Lou |
| Author: | mike elam [ Fri Nov 30, 2001 9:59 am ] |
: That skip in my 75 dart is much better with the : wire so I will take the instrument panel out : and see if the problem is in the amp gauge. : Could the ignition switch be shorting? : Thanks again. Thanks lou I will give it a try this weed end. melam@nxs.net |
