It is currently Sat Nov 28, 2026 10:56 am
 Post subject: wheel bearings Help.
PostPosted: Fri Nov 30, 2001 1:53 pm
Replacing wheel bearings, races, and seal. (65 B-Cuda). How tight should i tighten the front drum spindle nut. And do I fill the area (between) the inner and outer bearings (in the drum) with grease. Thanks for helping.
 Post subject: Re: wheel bearings Help.
PostPosted: Fri Nov 30, 2001 8:34 pm
: Replacing wheel bearings, races, and seal. (65
: B-Cuda). How tight should i tighten the
: front drum spindle nut. And do I fill the
: area (between) the inner and outer bearings
: (in the drum) with grease. Thanks for
: helping.
What I do is tighten them down pretty tight and roll the wheel around a couple times. Then, I back the nut off until it is loose, and tighten it until it is just over hand tight. Then I tighten it until the cotter key can be installed. Get them too tight and the bearings will burn up. I don't put any extra grease in the hub or the dust cap. Dennis
slantzilla@excite.com
PostPosted: Sun Dec 02, 2001 8:03 am
: What I do is tighten them down pretty tight and
: roll the wheel around a couple times. Then,
: I back the nut off until it is loose, and
: tighten it until it is just over hand tight.
: Then I tighten it until the cotter key can
: be installed. Get them too tight and the
: bearings will burn up. I don't put any extra
: grease in the hub or the dust cap. Dennis
Thanks, got it all back together and it drives great(no more vibrations).
