| wheel bearings Help. https://slantsix.org/forum/viewtopic.php?t=2924 |
| Author: | Terry [ Fri Nov 30, 2001 1:53 pm ] |
| Post subject: | wheel bearings Help. |
Replacing wheel bearings, races, and seal. (65 B-Cuda). How tight should i tighten the front drum spindle nut. And do I fill the area (between) the inner and outer bearings (in the drum) with grease. Thanks for helping. |
| Author: | dschumers [ Fri Nov 30, 2001 8:34 pm ] |
| Post subject: | Re: wheel bearings Help. |
: Replacing wheel bearings, races, and seal. (65 : B-Cuda). How tight should i tighten the : front drum spindle nut. And do I fill the : area (between) the inner and outer bearings : (in the drum) with grease. Thanks for : helping. What I do is tighten them down pretty tight and roll the wheel around a couple times. Then, I back the nut off until it is loose, and tighten it until it is just over hand tight. Then I tighten it until the cotter key can be installed. Get them too tight and the bearings will burn up. I don't put any extra grease in the hub or the dust cap. Dennis slantzilla@excite.com |
| Author: | Terry [ Sun Dec 02, 2001 8:03 am ] |
: What I do is tighten them down pretty tight and : roll the wheel around a couple times. Then, : I back the nut off until it is loose, and : tighten it until it is just over hand tight. : Then I tighten it until the cotter key can : be installed. Get them too tight and the : bearings will burn up. I don't put any extra : grease in the hub or the dust cap. Dennis Thanks, got it all back together and it drives great(no more vibrations). |
