It is currently Mon Jun 22, 2026 7:39 pm
 Post subject: Driveshaft length
PostPosted: Thu Jun 05, 2008 12:29 pm
When I swap my A904 out for the A833, will it be necessary to get a longer driveshaft (or shorten the one I have), or will I just be able to swap on the new slip yoke for the 833 and be good to go?
PostPosted: Thu Jun 05, 2008 2:08 pm
If you have an A/F body 833 you'll just have to change yokes. :shock:
 Post subject: You might check first...
PostPosted: Thu Jun 05, 2008 8:11 pm
More than likely yes, but depending on the year of the tranny (like certain late 70's A-833 OD's) you may be able to use the A904 yoke (straight A-833 will be the other yoke like D says...)
PostPosted: Fri Jun 06, 2008 5:49 am
I know later models used the slip-yoke type. I can't remember the output shaft spline count off the top of my head, but I seem to remember it being different from early-mid 70's A904s. Am I mistaken here? The car I'm using as a reference (since I want an OD unit) is a '79 Dodge Aspen.
PostPosted: Fri Jun 06, 2008 9:35 pm
Anything goes... there are some A-230 boxes from the mid-70's that are splined for the A-727 yoke... I have a 1978 A-833OD Tranny (and a 1975 Iron case tranny... they both seem to 'fit' with the yoke from the 1967 A-904 tranny...)... I also have a couple of 1976 A-833 OD boxes that take the A-833/727 yoke... so it's pretty hit and miss, with junkyard parts sometimes...
pull the yoke count the splines and if it's a 'go' then that's one less change for you to have to make...
-d.Idiot
