It is currently Fri Jun 12, 2026 8:10 pm
PostPosted: Thu Jun 05, 2008 9:11 pm
I think that the temp guage in my Daughters 72 Valiant may be reading a little too much to the right hand side of the guage.Does anyone know where approxamatly 180-195 degrees shoulbe on the factory guage?
I thought that the engine may be running hot but I used a infrared thermometer and shot the water in the top radiator tank and it read 177-185 degrees and then shot the thermostat housing and it read 187-195 degrees ,seems like normal temps to me and the coolant is flowing well and not puking out the overflow hose and I can take the cap off while running with no gushing or pressure build up,also there are no bubbles at all in the coolant while running.
I have already installed a new sending unit and the thermostat is a practically new 180 degree Stant.The temp guage reads on the second small mark on the guage about 3/4 over on the face.
Any help is as always very appreciated.
HyperValiant
PostPosted: Fri Jun 06, 2008 8:44 am
How's the accuracy of the fuel gauge?
PostPosted: Sun Jun 08, 2008 11:21 pm
Mine's a 318 and the temp indicator pointer is just a needle width past even with the lower index of the arc when I'm indicating 180-185 with themometer in top tank and IR reading at the thermostat housing. Don't know whether this factory design spec or not, but works for me. Hope this helps.
PostPosted: Tue Jun 10, 2008 8:05 pm
Dan,I apolagize for not getting back to you but have been away from the computer for a few days but found that the car was actually running hot.I tested with a aftermarket guage and it read about 220 after a long idle session.
I traced the problem to a semi-stopped up radiator and have a less stopped up radiator in for the time being until I can lay hands on a new one.
Thanks for your help
HyperValiant
