It is currently Wed Nov 25, 2026 3:54 pm
 Post subject: bad torsion bars?
PostPosted: Sun Jun 08, 2008 6:34 pm
so i went to replace my 890R/891L t-bars in my /6 scamp with some old 892R/893L bars i had from an old duster. seems as if the duster bars have lost their 30* twist, and the twist is only about 10* now, and the right bar has a slight bend to it.
is it even possible for t-bars to loose their twist? the only way i can get these bars into the scamp is to put the right bar on the drivers side, and left bar on the pass. side, but they do work.
seeing as i basically destroyed my old bars getting em out am i screwed and should just buy some new bars?
PostPosted: Mon Jun 09, 2008 7:59 am
Yes, springs can lose tension over time, or "take a set".
No, don't swap bars side-to-side.
I'd look for some different bars - and use a gentler method to get them out! :wink:
