| bad torsion bars? https://slantsix.org/forum/viewtopic.php?t=29391 |
| Author: | dmopar74 [ Sun Jun 08, 2008 6:34 pm ] |
| Post subject: | bad torsion bars? |
so i went to replace my 890R/891L t-bars in my /6 scamp with some old 892R/893L bars i had from an old duster. seems as if the duster bars have lost their 30* twist, and the twist is only about 10* now, and the right bar has a slight bend to it. is it even possible for t-bars to loose their twist? the only way i can get these bars into the scamp is to put the right bar on the drivers side, and left bar on the pass. side, but they do work. seeing as i basically destroyed my old bars getting em out am i screwed and should just buy some new bars? |
| Author: | slantvaliant [ Mon Jun 09, 2008 7:59 am ] |
Yes, springs can lose tension over time, or "take a set". No, don't swap bars side-to-side. I'd look for some different bars - and use a gentler method to get them out! |
