It is currently Tue Jun 02, 2026 5:59 pm
PostPosted: Tue Jun 10, 2008 2:49 am
Location: La Milesse FRANCE near the 24 hours of Le Mans
Hi
i've got trouble with my new holley 390 cfm. I don't know how many turn i have to do with the idle mixture needles. The engine runs well, but when i put the drive position it stalls. Probably the mixture is too rich ?
Holley 390 cfm, clifford manifold, pertronix ignition, stock exhaust and stock manifold.
thanks
Dodge dart 270 four door sedan with 170 ci slant.
Video post you tube dodge dart 1965
 Post subject: Idle not high enough....
PostPosted: Tue Jun 10, 2008 5:27 am
Actually in this case, it may be rich enough, but the idle screw is set too low.... you should block the wheels, have a buddy in the car step on the brake and put in drive... set your idle at that point (try 800 rpm or a bit more if it's still stalling)...
PostPosted: Tue Jun 10, 2008 7:40 am
Don't want to steal the show but i've got a similar problem but its the opposite. Mine runs to high at about 1200rpm's, and thats the lowest. I noticed I can force the throttle closed and it will be alright. I actually just put a strong spring on it. Am I missing another adjustment?
1980 dodge custom 150, 225 slanter, four on the floor, restoring lil by lil. So far the engine has the clifford intake and headers, holley 390cfm vacuum secondary, all stock from there.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
