It is currently Thu Nov 26, 2026 9:13 am
PostPosted: Tue Jul 01, 2008 9:46 am
I did a disk brake conversion on my 72 Duster and have installed the new master cylinder and bled the brakes, but when I push on the brakes really hard the brake light keeps coming on. So I bleed them again and try it again and the brake light comes on again. What am I missing here?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Jul 01, 2008 10:17 am
When you do push the pedal hard, does it sink or do anything else abnormally?
Did you replace the distribution block when you did the swap too?
PostPosted: Tue Jul 01, 2008 10:29 am
The brake warning light switch activates when there is a large enough difference in pressure between the front and rear hydraulic systems. I would have to say one side is loosing pressure. Is the master cylinder truly new or is it remanufactured? Are all three brake hoses new? Any leaks?
Users browsing this forum: No registered users and 15 guests
