It is currently Thu Nov 26, 2026 8:09 am
PostPosted: Tue Jul 01, 2008 9:46 am
I did a disk brake conversion on my 72 Duster and have installed the new master cylinder and bled the brakes, but when I push on the brakes really hard the brake light keeps coming on. So I bleed them again and try it again and the brake light comes on again. What am I missing here?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Jul 01, 2008 10:17 am
When you do push the pedal hard, does it sink or do anything else abnormally?
Did you replace the distribution block when you did the swap too?
PostPosted: Tue Jul 01, 2008 10:29 am
The brake warning light switch activates when there is a large enough difference in pressure between the front and rear hydraulic systems. I would have to say one side is loosing pressure. Is the master cylinder truly new or is it remanufactured? Are all three brake hoses new? Any leaks?
