It is currently Sun Jun 14, 2026 1:40 am
 Post subject: PCV for Weber carbs?
PostPosted: Wed Jun 11, 2008 12:31 pm
I'm about to install a 2bbl Weber carb (36DCNVA) onto an Offy 4bbl manifold with an adapter. Where do I connect the hose coming from the PCV?
Thanks, thanks, thanks, in advance!!!
Wes
'78 Volare 225
'67 Charger 318
PostPosted: Wed Jun 11, 2008 12:42 pm
Central manifold vacuum for even distribution.
Cheers, Wizard
PostPosted: Wed Jun 11, 2008 1:55 pm
I teed into my power brake line. So far, so good.
PostPosted: Wed Jun 11, 2008 6:36 pm
You "dont" want to hook it to the number six runner vacum port, it will lean that cylinder down and cause the exhaust valve to burn.
Jess
PostPosted: Wed Jun 11, 2008 6:48 pm
Jess is correct; you must not connect your PCV to the rearmost intake runner. It needs to go to the central plenum area of the intake. If there's no such provision on your Weber carb, drill and tap the intake or the adaptor for a pipe nipple.
PostPosted: Wed Jun 11, 2008 10:32 pm
Not to steal a thread, but you're saying I should move mine? It's not been on there but a few months, and I haven't changed the plugs yet, so I don't know what it might be doing to that cylinder. Am I destroying something?
Last edited by coconuteater64 on Wed Jun 11, 2008 10:34 pm, edited 1 time in total.
Still weber related
With the manifold project we will not be drilling the #6 boss - thinking of leaving it out totally.
The plenum balancer tube will be getting either a christmas tree or - a mini plenum with different nipples on it for pcv, brake booster, vacuum for ac etc.
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Jun 11, 2008 10:50 pm
Yup - that and the brake line to a central position - so all cylinder are affected the same way
If your carb is not equipped with a full vac port - you have to drill and tap the plenum and install a nipple - as Dan said
Regards,
Fanie Gerber
PostPosted: Thu Jun 12, 2008 7:28 am
Yes. Sooner = better. You're introducing a whackload of extra air into the rearmost cylinder and causing it to run lean. This is very bad for the health of cheap things like spark plugs and expensive things like valves and pistons.
I wouldn't worry about the power brake booster line, if applicable; a central location would be preferable for that one, but it just admits occasional gulps of not very much air and the factory did use the #6 runner for that hose.
PostPosted: Thu Jun 12, 2008 11:55 am
Will do! :shock:
PostPosted: Thu Jun 12, 2008 3:36 pm
coconuteater64
You should notice a smoother running engine when you move the PVC, Carb idle mix screw ajustment may be needed after making the move.
Jess
PostPosted: Fri Jun 13, 2008 11:09 am
Update: The Weber carb is on and she runs. I still need to hook up the trans kickdown linkage, and I still don't have the PCV hooked up yet. I guess I'll have to drill a hole and tap it, probably in the carb adapter.
Thanks for all the responses guys!
Wes
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jun 13, 2008 12:37 pm
My Offy manifold has a drilled and tapped hole on the outside center of the plenum. Would be easy to add if it's not already there.
PostPosted: Fri Jun 13, 2008 8:50 pm
Josh,
I read your reply, and then I remembered that there is a trheaded hole on my Offy manifold where you described. I plugged it with a brass plug years ago. Its not that big, but I guess a PCV port doesn't have to be big, is that right?
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jun 14, 2008 7:42 am
The PCV inlet needs an 11/32" O.D. pipe nipple. That's not a common size, so usually you go to 3/8".
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
