It is currently Mon Jun 01, 2026 11:45 pm
 Post subject: Holley Jets
PostPosted: Mon Jun 16, 2008 11:53 am
Anyone know a source for the jets for a Holley 2280 type carb? The jets in it are smaller than the standard old 4 barrel or Holley 1920 two barrel type carbs (which both use the same sort of jet).
Not started tuning it yet, but realized the jet size difference and so putting it out there to gain the info if needed later.
Cheers
From Mopars to classic Minis and back to Mopars in 19 years flat!
Will work for roast chicken crisps!!
PostPosted: Mon Jun 16, 2008 2:11 pm
Excuse my slip; I had thought the 2280 takes the ordinary jets like a 1920 or 1945, but in fact the 2280 takes the smaller jets. These are available in numerous orifice sizes from Walker; they're the "120-6" jet family as listed in Walker's Holley Metering & Jets catalogue (PDF). Probably also worth getting their Holley 2bbl master parts catalogue.
PostPosted: Mon Jun 16, 2008 3:50 pm
Dan,
Kindly please, is there a Canadian source/email contact for Walker parts particularly 5220/6520?
I saw that Walker parts do have throttle shaft sleeves and source of jets also finally hopefully metal floats if available. Also jets for these?
Oh, I'd love to find a damper pot that fits these as well? The computer kept overcorrecting by cycling the throttle in and out even I had it set up correctly so I have to disconnect the vacuum throttle kicker.
Cheers, Wizard
PostPosted: Mon Jun 16, 2008 4:41 pm
Hi,
Thanks for posting the links. I'll have a look through them and see what I can find. Might not need any jets, but then again, at the altitude (you know what that is about) I just might!
PostPosted: Mon Jun 16, 2008 5:58 pm
Wizard: Not sure. Give 'em a jingle and see if they have any Canadian distributors.
Brit: Glad to help!
PostPosted: Tue Jun 17, 2008 12:55 am
These guys can be a good source for carb parts. I dont know if they have parts for the carb in need here, but they do have a good listing of there parts on line and you can sift through there sub sections and see what you can find.
http://www.carburetion.com/
Jess
PostPosted: Tue Jun 17, 2008 5:20 am
Thanks for the post Lucky13. Did not see Holley stuff as needed, but did notice a listing for Carter 2 bbl. Might be a useful place for picking up pieces for someone tuning or repairing a Carter.
List of sources might be worth some sort of sticky perhaps, if I didnt already miss one that is :lol:
Cheers
PostPosted: Tue Jun 17, 2008 10:35 am
These guys can be a good source for carb parts. I dont know if they have parts for the carb in need here, but they do have a good listing of there parts on line and you can sift through there sub sections and see what you can find. http://www.carburetion.com/
Careful; these guys seem to have blown off and hosed one of our members.
