It is currently Thu Nov 26, 2026 12:47 am
PostPosted: Sun Jun 22, 2008 11:07 am
Will the front end parts from a 1980 aspen wagon go into a 1970 Dart? UCA, Spindles, etc? I need to convert my front end to BBP so I don't need to carry two spares. Will it work?
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sun Jun 22, 2008 11:23 am
The spindles with the calipers and brackets are all that you can use from the Aspen. You'll still need large ball joint A-body upper control arms, new lower ball joints, brake hoses and a master cylinder at a minimum.
You're welcome.
PostPosted: Sun Jun 22, 2008 11:28 am
D'oh.
Thanks.
