| Oil Press Drop https://slantsix.org/forum/viewtopic.php?t=2973 |
| Author: | Trysix [ Sun Dec 09, 2001 5:41 pm ] |
| Post subject: | Oil Press Drop |
I've noticed that on hard stops my oil pressure drops to 0 psi then returns to 40-50 lbs. I assume this is caused by oil puhing up in the pan and returning....Is this normal on a 65 - 225 ? I figured when I overhaul my Engine soon..I would build some baffles along with a windage screen. Any other Ideas? soupitup@msn.com |
| Author: | Doc [ Tue Dec 11, 2001 9:16 am ] |
| Post subject: | Re: Oil Press Drop when Stopping |
: I've noticed that on hard stops my oil pressure : drops to 0 psi then returns to 40-50 lbs. I : assume this is caused by oil puhing up in : the pan and returning....Is this normal on a : 65 - 225 ? : I figured when I overhaul my Engine soon..I : would build some baffles along with a : windage screen. Any other Ideas? I would weld a couple of baffels into the pan and be sure the oil pick-up tube is correct for that year oil pan and positioned close to the pan's floor. Tip: When doing pan baffels and windage trays, always check all clearances, including the dip stick's clearance. DD |
| Author: | Dart270 [ Tue Dec 11, 2001 2:32 pm ] |
: I would weld a couple of baffels into the pan : and be sure the oil pick-up tube is correct : for that year oil pan and positioned close : to the pan's floor. : : Tip: When doing pan baffels and windage trays, : always check all clearances, including the : dip stick's clearance. : DD I'll guess that last bit's a wee reference to my recent snafu... very polite. Lou |
| Author: | Doc [ Tue Dec 11, 2001 5:49 pm ] |
: I'll guess that last bit's a wee reference to : my recent snafu... very polite. : Lou As they say...been there, done that,... and it sounds like I am not the only one to put a nice oil pan / windage set-up onto an engine, just to find-out that the dip stick no longer has a place to get through to the sump. DD |
