It is currently Sat Jun 20, 2026 4:23 am
 Post subject: Slant 6 Head
PostPosted: Mon Jun 30, 2008 7:00 am
Head interchangeability 1982 to use on a 1969 slant 6?
Will there be problems?
Richard
PostPosted: Mon Jun 30, 2008 9:49 am
No. You will need to keep the rear rocker shaft bolt from the '82 head, and use the '82 valve cover. The '69 rocker shaft will bolt right on. :D
PostPosted: Mon Jun 30, 2008 9:51 am
You need the wide valve cover and gasket that goes with that head.
Are you planning to run the solid lifters and use the adjustable rocker arms off the 69 engine?
PostPosted: Mon Jun 30, 2008 11:11 am
I would be getting the gaskets with the head but not the wider valve cover. ANd i'd rather adjust lifters than change to the other kind.. I want to be sure that it will bolt on and I won't run into any starnge problems like when one works on a FORD.
Users browsing this forum: Ahrefs [Bot] and 3 guests
