Brake light keeps coming on
https://slantsix.org/forum/viewtopic.php?t=29822
Author:  bwhitejr [ Tue Jul 01, 2008 9:46 am ]
Post subject:  Brake light keeps coming on
I did a disk brake conversion on my 72 Duster and have installed the new master cylinder and bled the brakes, but when I push on the brakes really hard the brake light keeps coming on. So I bleed them again and try it again and the brake light comes on again. What am I missing here?
bwhitejr
Author:  Pierre [ Tue Jul 01, 2008 10:17 am ]
When you do push the pedal hard, does it sink or do anything else abnormally?
Did you replace the distribution block when you did the swap too?
Author:  Joshie225 [ Tue Jul 01, 2008 10:29 am ]
The brake warning light switch activates when there is a large enough difference in pressure between the front and rear hydraulic systems. I would have to say one side is loosing pressure. Is the master cylinder truly new or is it remanufactured? Are all three brake hoses new? Any leaks?
