It is currently Sat Jun 06, 2026 7:22 pm
 Post subject: Pulley wheel alingment
PostPosted: Wed Jul 02, 2008 8:52 am
Is there normally a spacer that goes between the water pump flange and the pulley wheel that bolts to it? The pulley wheel is too close to the block to line up correctly.
PostPosted: Wed Jul 02, 2008 9:07 am
No but you can get them. The pump probably has had the flange pressed on too far.
PostPosted: Wed Jul 02, 2008 9:28 am
Or you may have the wrong water pump pulley or the lower vibration dampener my not be pressed all the way onto the crank.
