| Pulley wheel alingment https://slantsix.org/forum/viewtopic.php?t=29835 |
| Author: | trdrew [ Wed Jul 02, 2008 8:52 am ] |
| Post subject: | Pulley wheel alingment |
Is there normally a spacer that goes between the water pump flange and the pulley wheel that bolts to it? The pulley wheel is too close to the block to line up correctly. |
| Author: | AnotherSix [ Wed Jul 02, 2008 9:07 am ] |
No but you can get them. The pump probably has had the flange pressed on too far. |
| Author: | Doc [ Wed Jul 02, 2008 9:28 am ] |
Or you may have the wrong water pump pulley or the lower vibration dampener my not be pressed all the way onto the crank. DD |
