Vacuum pressure
https://slantsix.org/forum/viewtopic.php?t=29923
Page 1 of 1
Author:  superman_jjs [ Tue Jul 08, 2008 2:17 pm ]
Post subject:  Vacuum pressure
How much vacuum should I see at idle?
I have right at 7 inches and at choke it is about 20.
Author:  Aggressive Ted [ Tue Jul 08, 2008 2:52 pm ]
Depends upon the rpm, in gear verses out of gear, one barrel or two.
I run about 16.5" in gear at 550 rpm on a 85 degree day.
18" out of gear with a Holley 1920.
Author:  tophat [ Tue Jul 08, 2008 5:32 pm ]
With a carter 2bbl on a super six manifold and a stock cam I see 15"~16" at an 650 rpm idle in neutral. I have my dash gauge hooked in to a T fitting in the pcv hose. My second dash gauge is hooked in to a T fitting in to the vacuum advance at the distributor, I see as much as 20" inches at cruise.
TopHat
